Need advice on thermostat wiring for carrier Furnace and AC
Hi,
I have:
Carrier 58MN7A Furnace (two stage)
Carrier 24ANB6 A/C (I think is single stage only based on only having three wires going to it)
I am wiring in a new thermostat and have a question about the wiring.
My question is for the A/C wiring in particular.
The MB in the Carrier Furnace has a connector for Y/Y2 and Y1
The MB in the Carrier A/C has a connector for only Y
Is it wrong to connect both the Y/Y2 and Y1 wires to the Thermostat?
Connecting the wire makes the system think I have dual stage cooling... but I wasn't sure if this is for fan control or something else and that I need to have a dual stage A/C unit for this.
Your help is greatly appreciated.
Thanks
D.
I have:
Thanks
D.
Received 41 Upvotes
Here is a link to the A/C installation manual. Toward the end it show thermostat wiring.
http://dms.hvacpartners.com/docs/100...24anb6-3si.pdf
