York stellar plus furnace problems
Old 02-16-15, 06:17 AM
Ok so heres the problem I would greatly appreciate it if you could help me.
I have a york stellar plus furnace. Just here recently I replaced the thermostat. And everything started working fine. Then last night I could not get any heat to come on. I looked at my furnace and I saw a little orange glow and right before it sounded like it was going to start the glow just went dead..about a minute later it just did the same thing. I shut off my thermostat over night and then this morning I decided to turn it on. Somehow my heater started blowing hot air again but only to last for about 5 minutes and it shut off. I have no clue whats going on but I feel that this could be an easy fix. I just don't have the knowledge. PLEASE HELP ME. Thanks guys!
Old 02-16-15, 09:59 AM
Received 4,051 Upvotes on 3,634 Posts
Welcome to the forums.
Have you had the furnace serviced ? It should be serviced every year or every other year.
A model number for your furnace would be helpful.
Is there a fan that starts when the thermostat calls for heat ?
It's called a draft inducer. Circled in orange below.
You need to pull the burner door off and describe to us exactly what happens.
