Rheem Sillhouette gas furnace Indoor Blower Motor does not stop
Old 02-16-15, 10:15 AM
T
Exclamation Rheem Sillhouette gas furnace Indoor Blower Motor does not stop
Hi all, been trying to diagnose Rheem Silhouette gas furnace UGDG-075AUER. The indoor blower motor seems to be stuck. It starts before the induced draft motor and never stops even after thermostat is turned off. I wonder if i have a short?
Old 02-16-15, 11:15 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Welcome, FixitGuy. Since I can't access any Rheem manuals online, this could take a while.
Is there any kind of blink code showing. There's usually a small window in the blower compartment door thru which you can see a (usually red) LED. Count the blinks then remove the blower compartmet door. On the inside of the door is usually the key to the blink code.
