Lennox G40UH(X) Induction fan - no operation
Old 02-16-15, 06:43 PM
It's -10 degrees and my furnace died. It's a Lennox model: G40UH(X). When I turn it on I can hear several relays click, then a steady hum, the diagnostic LEDs indicate "power on - Normal operation" (both LEDs - slow flash). But, nothing happens. According to the manual the induction air inducer is supposed to kick on. I jumpered 120V to the induction air inducer motor to ensure it operates and it started right up. Any ideas why it's not receiving power?
Old 02-20-15, 11:08 PM
Just a wild guess, but maybe the thermostat isn't sending the signal to start up your furnace?
Old 02-20-15, 11:16 PM
Received 3,877 Upvotes on 3,475 Posts
Welcome to the forums.
More than likely the relay on the control board either has a solder problem or the contacts are dirty. When the unit calls for heat.... tap gently on the control board with the handle of a screwdriver.
