American standard furnace only runs for a few minutes then turned off?
Old 02-17-15, 09:26 AM
T
Exclamation American standard furnace only runs for a few minutes then turned off?
Gas to the furnace was turned off after 3 minutes of burn time, then blinks 4 times, the furnace will restart again and turn ordinary LED flashes!!
This cycle repeats until the temperature reaches the current set of heat as nothing goes wrong! What needs to be changed here? Please HELP
** it only happened since yesterday.
Model number: CUB100A948C4
Old 02-17-15, 10:43 AM
Look for the codes on the inside of the blower cover. Let us know what 4 blinks means.
Old 02-17-15, 12:14 PM
Received 3,196 Likes on 2,871 Posts
Welcome to the forums.
Four flashes indicates an open high heat safety stat. This usually indicates a poor airflow problem. The first place to start is to check the air filter and replace if dirty. Make sure the return vents aren't blocked and that too many supply registers aren't closed off.
If those all check out ok you may have an A/C coil that has become plugged with dust.
Old 02-20-15, 01:30 PM
T
Thank you PJmax, I have replaced the air filter and the problem is solved! It's really easy, but I never knew.
