Honeywell SV9541 Smart Valve - 6 and 4 flashes
Old 02-17-15, 05:50 PM
B
Howdy All,
I have a question about my furnance.
I have the SV9541 Smart Valve with an ST9160B 1050 Fan Control Board.
I had the unit off the other day because my office is near the furnace and I was on a call.
When I turned it back on the temp had drops a few degrees in the house (we live in WI), and I noticed that the furnace turned on and a while later it was off but the temp hadn't come back up to the set point.
I looked at the valve and I see the status LED flashing 4 then 6 flashes. It could be 6 then 4, not sure how to tell which comes first.
While I was reading in the manual, the furnace restarted and ran for quiet a while (not sure the exact number of minutes). While running the status LED is giving the heartbeat as I would expect.
Then it turned off again and gave the same 4 and 6 flashes. It will continue to run this way indefinitely, I believe.
I checked the pressure switches and they seem fine.
Any thoughts?
Thanks,
Brian
Old 02-17-15, 07:36 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Four flashes indicates an open limit. Six flashes means the control is in a five minute delay. Here is the manual on the valve. Troubleshooting begins on page 16. https://customer.honeywell.com/resou...0s/69-1227.pdf
