Furnace blowing cold air
Old 02-24-15, 01:09 PM
G
I have a Beckett furnace and I ran out of fuel, I filled the tank and the furnace comes on but it only blows cold air and the red light is flashing indicating a soft lockout, what should I do to get it running again
Old 02-24-15, 02:39 PM
user 10's Avatar
Received 57 Upvotes on 50 Posts
Is this an oil or propane furnace? If yes, I think there's a button on the control you can push to reset it.
Only push it once, then call a tech.
Old 02-24-15, 04:13 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
If you only have one fuel line going to the pump, the pump is full of air & must be bled. To do so, you will need a 3/8" wrench, a hose (even a drinking straw will work), & a container to catch the oil. Put the hose over the brake bleeder valve sticking out of the pump at the bottom right, push the reset, hold the hose into the container, & quickly open the bleeder about 1/3 to 1/2 turn with the wrench. When you get a full flow of oil or the burner kicks off, shut the bleeder.
