Do you have to pump condensate away?
or could you let it drip into a container to evaporate away, presumably something built for that purpose? Although I have not yet discovered such a container so it seems there is reason people don't do this.
I assume you don't have a floor drain nearby. I just wouldn't want standing water in my basement. A condensate pump would be your best bet.
Allowing the moisture you removed from the conditioned space to evaporate back into the conditioned space negates the effectiveness of the system.
Sorry, I didn't specify. This condensate is coming from a furnace and a water heater. No air conditioning involved. If anything, where we live, we could do with higher humidity.
We don't have a floor drain nearby and a pump is currently pumping the condensate from both lines through a tube in the ceiling over to a utility sink. On top of having the tube and yet another electrical appliance plugged in you're supposed to change out the neutralizer every once in a while because condensate is acidic. It strikes me as a slightly jury-rigged affair when the simple solution could be to just let it evaporate from a container designed for that purpose. Like a bucket lined with a hydrophilic material to encourage capillary action. Just haven't found anything like that yet in my searches.
My furnace contractor suggested that when he installs my new furnace, he would just install a neutralizer along the PVC which goes across my basement ceiling and drips into a utility/basement sink as well.
Have you seen any problems with this method? I was skeptical at first, but he said it's within code and the right thing to do.
Received 39 Upvotes
Kevin: That is a well accepted method.
Evan: In order to get enough evaporation, you would have to use some sort or heated container. A condensing gas furnace produces a lot of water since water is a by-product of combustion.
Received 39 Upvotes
You are most welcome. You might be able to get rid of some of it by re-routing to a humidifier but I doubt all of it. Besides, the acid would be mighty hard on a humidifier & possibly the ductwork. Wish I had a better answer for you but I'm afraid you're stuck with the pump just be sure to clean it once in a while.
