Copper tubing for fuel oil
I want to run some new copper tubing from my tank outside to the floor heater under my house. Currently I have 3/8" tubing in place that has been there since probably late 80's to early 90's. I bought a 50 ft coil of 3/8" O.D. from Lowes. I asked the sales kid what type it was and he told me that it was Type L. From what I've read Type L is acceptable for fuel oil. My roommate is questioning the label on the box because it says "Refrigeration 3/8" x 50 ft".
So does this sound like I got the proper tubing even though it says "Refrigeration" on the box?
Shades
Shades
Thanks PJMax!
One last question, my roommate insists that it should be 3/8" I.D. whereas I have 3/8" O.D. that the walls of the tubing is thinner and the I.D walls are thicker and better for fuel oil. Is there any reason I shouldn't use what I have or return it and exchange it for I.D. 3/8"?
Shades
Shades
See if this chart helps some..... the OD remains constant for 3/8" copper.
Type L is commonly used for oil tanks.
So the chart is saying that the wall thickness on a 3/8" O.D. is 0.500 which is actually thicker than the I.D. of 0.430?
Hopefully last question. I appreciate your expertise.
Shades
Shades
No... it's saying that with 3/8" copper pipe.... the OD is always .500
The ID and the wall thickness depends on type of pipe.
Received 38 Upvotes
3/8 inch copper tubing as used with refrigeration and fuel oil systems is 3/8 inch outside diameter. Tubing is always measured by its outside diameter. 1/2 inch nominal copper water piping is 5/8 inch outside diameter.
I removed my incorrect chart. It was incorrectly in the place of standard copper tubing not roll tubing.
Thanks for the correction... Furd
So use the 3/8 soft roll copper and all will be good. Make sure the pipe is clean at the compression fittings.
