Lennox Furnace
Old 03-29-15, 08:10 PM
T
Lennox Furnace
Hello everyone,
Having a problem with my Lennox furnace. This winter out of the blue while the heat was on the A/C unit outside kicked on. After looking at it I found out that the heat would run for a few minutes and then the unit would turn on outside. This would happen sometimes and then not. Nothing was changed or worked on the system. I replaced the thermostat thinking that was it but that made no difference. I have a simple dial thermostat nothing fancy. below are the model # and Ser # if that helps. I live in the Chicago area and it is not a heat pump system. Thanks for any help in this. I have turned the breaker off to the unit outside till I figure this out.
Model# G12Q3-82-6
Serial # 2187M65089
Old 03-29-15, 09:25 PM
user 10's Avatar
Received 52 Upvotes on 46 Posts
What's the model of the a/c?
There's probably an issue (like a short) in the low voltage wiring.
The furnace is a 1987 and I suggest you get the heat exchanger inspected. It's probably cracked by now. https://www.youtube.com/watch?v=tIZ20EA6v04
Old 03-30-15, 07:21 AM
T
Muggle I would assume the low voltage wire your talking about is from the thermostat to the furnace? That was going to be the next thing I was going to do. was run a new wire. The furnace was installed when the town-home was built in 1991. Did they have this sitting around for four years before the built the place? that would stink if that was the case.
Old 03-30-15, 07:25 AM
T
Please see the above post. Thanks.
Old 03-30-15, 10:16 AM
Check the stat terminal strip in the furnace. Make sure the Y wire is not touching any other wires.
Old 03-30-15, 11:37 AM
user 10's Avatar
yes, the issue could be in the furnace itself.
its possible that the furnace was sitting for a few years - maybe the installer got a good deal on many g12s
