BTU calculation
Old 04-01-01, 08:53 AM
Guest
I need to determine the BTUs for a 16x12x9 ft room w/ three 3 6x3 ft double-paneled windows, with wall insulation fair/average in southern Wisconsin, hydroponic heating system.
Old 04-01-01, 11:29 AM
fjrachel
With that much glass in one room and being in a colder climite, I would have a heat load calculation done on the room to be sure. Search the net for home heat load calculations.
Old 04-01-01, 11:38 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello and Welcome big_daddy to the Do It Yourself Web Site.
On average and with all dimensions taken into consideration, the formular is:
40 BTU's per square foot.
Therefore, {if my calculations are correct... }
16 x 12 = 192 sq. ft. x 40 btu's = 7,680
The amount of BTU's needed to heat that room should be 7,680.
Regards & Good Luck
Forum Moderator
Tom_Bartco
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Old 04-02-01, 04:06 AM
PDF
If , when you shop
for heat,and find a heat unit at 7000 btu or 8000 btu go with the larger for those unusual cold days.PDF
