Propane Furnace Converted to Natural Gas
Hi, I recently purchased a house with a furnace that was once propane and since has been converted to burn natural gas. To be honest, I'm just trying to be pro-active to know how to find parts because of course furnaces always quit at the worse time.
Incase there's any info you need along the way, here is a link to some pics: https://www.dropbox.com/sh/tlu0t8xzn...b5zHmAYua?dl=0
So from what I could tell my model number is either culk100DH01 or CGK100P01 or both, however neither one brings anything up in google. I normally use RepairClinic.com (which I highly recommend) to buy parts based on the model number of the unit, but the search does not work there either. Also, would that be the model number of the propane version? How many parts are changed out to turn it to natural gas?
I tried searching "Heil Ultimate III" but that brought too many results as it seems like some sort of name brand...?
Any advice on how to find something to search (hoping to not have to search each part individually) would be greatly appreciated.
Thank you
Thank you
Converting Nat gas is very simple. Not much can go wrong on the converted parts. Except maybe the orifices become clogged. I wouldn't worry about.
Ok, my worry isn't only with the coveted parts. Anything can go wrong from a flame roll out switch to a circuit board.
I'd just like to know how to search for my model to be honest as the model number doesn't seem to be found...
The propane-to-gas conversion only involves the burner - which is a passive component, not involving the boiler itself. I'd forget about your concern, at least as I understand it, unless you are experiencing problems.
Thanks PJmax. I'm not sure how to verify if that is my furnace though? Would there be a trick to doing this? I'm assuming it has to do with the manufacturers and the fact that 100DH01 match, other than that I'm not sure how to take the next step to ensure it is the same?
Thanks for your time.
