creaking baseboard pipes
Old 04-02-01, 08:32 AM
Guest
When our baseboard pipes were installed upstairs. They did not make the whole in wall big enough for the pipes. When the heat comes on, the pipes expand and rub against the wood. It makes an awful creaking, snapping noise. We made a temporary fix with graphite. Does anybody have any other suggestions to permanetly eliminate these noises? We have oil heat.
Old 04-02-01, 02:47 PM
fjrachel
Cut the hole around the pipes larger.
Old 04-02-01, 03:12 PM
PDF
Something like
a hacksaw,but it's different.the blade fits into a handle,the blade extends beyond the saw.It can be picked up at most hardware stores.Explain to them the purpose you need it for.Carefully and gently enlarge the hole around the piping.PDF
