New thermocouple, no pilot light
Old 08-26-15, 09:05 AM
I tried firing up the space heater that i have yet to use since buying a home. I push in the pilot button and light the gas which points at the thermocouple , the gas cuts off after releasing the button.
I replace the thermocouple with a brand new one and repeat the process. Same result.
I then tried the process again but this i added a gas torch to the pilot flame. I was able to quickly heat the thermocouple to glowing orange. Same result.
What is the next step?
Old 08-26-15, 09:36 AM
Received 8 Votes on 8 Posts
Could be a problem with the gas valve itself.
Old 08-26-15, 11:05 AM
Yes I'm afraid that may be the case. I did try a third thermocouple after my dad told me sometimes you can buy a bad part. Same result.
How can i check the regulator?
Old 08-26-15, 02:08 PM
I don't know how to check it, beyond knowing that the problem clearly isn't the thermocouple. I would replace the gas valve.
Old 08-26-15, 08:17 PM
Received 517 Votes on 487 Posts
What kind of heater is this ? Do you have a make and model number ?
