No hot water
Old 04-07-01, 04:50 AM
Guest
Angry
I have a Watts 70A Regulator on my tankless hot water/furnace. I replaced the Thermostatic Assembly but it didn't help. I think the spring loaded valve at the cold water inlet of the valve is stuck open. Any suggestions. (replace the valve... I know)
Old 04-07-01, 07:56 AM
PDF
Are you saying
That you have water flow thru the heater?or no water flow?or just no hot water?PDF
Old 04-07-01, 09:59 AM
Guest
no hot water
The hot water is not flowing through the valve. I talked with a plumber and his suggestion was to take a screwdriver to the springloaded plunger at the bottom of the valve and see if i can free it up. i will try that today. (fingers crossed.) How can I tell if I have flow through the coil?
[Edited by Richs43 on 04-07-01 at 07:59]
