Rheem Criterion Propane Furnace Won't Turn On
Old 12-21-15, 06:25 AM
G
I have a Rheem Criterion Propane Furnace that will not turn on. The unit was installed in 2004. I have checked the circuit breaker, I have tried turning the thermostat up by 10 degrees. I have turned the unit off and then back on. The unit does not turn on at all, it is not blowing any air. Any ideas?
Old 12-21-15, 11:05 AM
Received 3,982 Upvotes on 3,574 Posts
Welcome to the forums.
You haven't given us much to work with.
Was it working and then just stopped ?
Is this the first time on this season ?
Does it also have A/C.... does that work ?
Is there a service switch on the side of the furnace that may be off ?
Is the blower door on solidly ? There is a safety switch in there.
Is there a sight glass on the blower door..... if yes.... look in and see if you see a red blinking LED.
