Furnace inducer problem
Old 12-31-15, 09:45 AM
induction motor clicks on for a few seconds then off.
Old 12-31-15, 09:52 AM
Welcome to the forums.
Not a typical problem. Usually the inducer wont run or runs for 30 seconds and then defaults. Most furnaces have a sight glass in the blower door to see a blinking LED trouble light.
Post the make and model so I can give you more detailed information. The ID tag is located on the inside wall near the burner.
Old 12-31-15, 11:56 AM
Goodman gmh81155cnac is the model
Old 12-31-15, 12:29 PM
I'm leaving the link to the Goodman service manual.
http://www.alpinehomeair.com/_viewresource.cfm?ID=2470
I'm on the road and will return later. Try getting a trouble code from the furnace too.
Also.... if you have a battery operated thermostat.... you may need new batteries.
