Carrier 9200 error code 31
Old 12-31-15, 02:08 PM
My Carrier Weathrmaker 9200 wont ignite. I am getting error code 31 from the blinking led light. The inductor motor is not running, just humming(and is hot). I disconnected the condensate trap and ran water through it to check for blockage. I don't have access to air intake pipe (roof), so cant check those.
Called a local service and he said the inductor motor probably needs replacing (without looking at it)and quoted about $700, then said since the furnace is 20 years old it may need replaced. I'm not ready to go that route if I can help it.
Also, I replaced the thermostat yesterday with a new wifi one, system ran all last night, but started to work intermittently this morning so I reinstalled original tstat, but did not work. May be unrelated but quite a conicindence.
Any thoughts or suggestions?
Old 12-31-15, 02:44 PM
To put it simply no inducer no flame. They might be right about the inducer motor being bad.
Old 12-31-15, 11:41 PM
You should have spent the money on the inducer.
You can post the FULL furnace model number if you'd like help ID'ing the inducer blower.
The inducers run roughly $200.
