Beckett Furnace stopping
Old 01-03-16, 05:19 PM
Beckett Furnace AFG runs as expected, good heat, blowers work reaches desired temp. then shuts off flame, but on some cycles the damper rattles and flame is restarted by relay then goes out. On/off on /Off in seconds. When this happens I shut off the entire switch, and then after five seconds flip the switch back on. Flame stays out and the furnace continues as it should with the blower blowing until the unit cools and then is ready for the next start. Replaced the Honeywell 8148m1051 two years ago. New nozzle, new oil filter, new air filter. Suggestions??
Many Thanks
Mic
Old 01-05-16, 06:27 PM
Rapid cycling on and off as I interpreted your description indicates a bad primary reset control, replace it with a R7284, waaayyyy better than than that R8184m model.
Old 01-06-16, 05:59 AM
ctoilman
Spot on! Had a service mechanic come out and thought it might have been the cad eye, after a quick repair found the trouble to be the primary reset control. Have already ordered the same but will heed you advice and look into the other. The current item is still under warranty. Many thanks for you help.
