90%+ new heater ...steam???
Old 01-05-16, 07:26 AM
Hi,
I just got a new heater installed. The exhaust goes outside and up the wall of my house about 12 feet. It's 3" PVC with a 90 an elbow at the top.
I'm noticing a fair amount of steam coming out from this "chimney".
Is this normal?
This should share as a slide show:
GregA41 Gallery - SlickPic
Old 01-05-16, 07:51 AM
Received 2 Votes on 2 Posts
Water/Moisture is a by product of combustion, especially in higher efficiency furnaces. On colder days, you'll see the moisture in the exhaust gas. Sorta like when you breath out on a very cold day. You can also see this in cars tail pipes in the early mornings.
Yes, it's normal.
Old 01-08-16, 05:38 AM
Thanks Tom, your answer makes perfect sense. I was just surprised by how much steam was escaping; I didn't expect to see clouds!
Old 01-09-16, 12:17 AM
Received 343 Votes on 321 Posts
If the humidity gets high enough and it gets cold enough..... you'll have ice and icicles hanging from the pipe.
Old 01-09-16, 07:33 AM
GregH's Avatar
Super Moderator
Received 8 Votes on 8 Posts
My spidey sense tells me you are in a climate zone where you would expect steam.
I woud suggest you go back and add your location to your profile to help with any future questions.
