Empire wall furnace GWT 50-1 will not turn on
Old 01-05-16, 01:56 PM
Pilot goes out when thermostat is turned up to bring heater on. I have replaced the thermopile and the gas valve. And still have the same result.
Old 01-05-16, 04:51 PM
Received 327 Votes on 306 Posts
Welcome to the forums.
It sounds like a dirty pilot light. Possibly a plugged orifice. The pilot generator requires a good pilot flame to generate enough voltage to operate the valves.
This is your installation/maintenance manual. There is an excellent diagnostic section on page 7. The pilot flame characteristics as well as voltage measurements are discussed.
empire zone heat/ArchiveManuals/B-VentGravityFurnace/GWT50-1.pdf
Old 01-06-16, 12:27 PM
SeattlePioneer's Avatar
<<Pilot goes out when thermostat is turned up to bring heater on. I have replaced the thermopile and the gas valve. And still have the same result.>>
Post the make and model of the gas valve you took out and that you installed.
Describe the appearance of the pilot flame.
