Goodman GKS9 not working
Old 01-12-16, 12:29 PM
Have a gks9 in my shop and i dont get much use out of it. Used a couple of times this winter and shut off after use. Went to start it and it attempted to ignite. Two burners came on briefly but wouldnt stay lit.
Checked viewing window and noted that the red light was blinking three times. Could condensation have formed and plugged the intake somewhere after i turned it off and the temp droppd below freezing? I attempted to light the furnace with the panel removed to view the burners.
Really appeciate some help with this. Thanks
Old 01-12-16, 12:52 PM
SeattlePioneer's Avatar
This furnace is a 90% condensing gas furnace:
http://www.goodmanmfg.com/Portals/0/pdf/SS/SS-GKS9.pdf
Old 01-12-16, 12:59 PM
The Goodman 3 flash code indicates that the pressure switch isn't closing.
Yes, frozen condensate could cause that problem, but so could many other things.
Check the rubber hoses to and from the pressure switch for cracks, holes or water.
Inspect and clean out the fitting for the rubber hose on the inducer motor housing. Using a small drill bit works well --- make sure the drill bit gets all the way into the inducer motor housing when cleaning. Use pliers to hold the drill bit so you don;t drop it into the inducer motor housing!
Check all the PVC pipe for sags which might accumulate water. Pull off the air inlet pvc pipe to the furnace and inspect for leaves or debris. --Check to see if the furnace will fire up with the combustion air supply disconnected, then do the same kind of inspection with the pipe venting the comustion gases.
Wikll the furnace operate with both PVC pipes disconnected?
Those are things to check for openers. Don;t bother replacing the pressure switch ---it's almost never the problem.
Old 01-12-16, 01:02 PM
Yes it is. It has a drain.
Old 01-12-16, 01:05 PM
Thanks!
....l.l.l..l,l.l.l.l.....l
