Help wiring Century blower motor
Old 01-14-16, 04:26 PM
Had to replace by furnace blower motor, but have ran into some difficulty as the new blower motor (century 1/2 horse power) has different color wiring.
I'm not sure where the yellow wire goes on the new century motor. I thought it would connect to the white (for power?), but it's a no go.
The old motor (general electric) did have a white wire that connected for power (?).
I do see a white wire on the century, but it's short and connected to itself (purple wire). Not sure why. I think that is what is throwing me off as the century has short wires plugged into other colors, but I don't know what to do with them.
I'm lost.
Thanks.
Here are some pics:
Century Furnace Wiring? - Album on Imgur
Old 01-14-16, 05:27 PM
Grady's Avatar
Received 1 Vote on 1 Post
The wires in question in the first picture are for changing the direction of rotation.
In the second picture, the two browns went to the capacitor & the white to neutral.
There should be a wiring diagram either on the new motor or packaged with it.
Old 01-14-16, 09:02 PM
No diagram came with the box.
The orange has to go to the white is my guess.
I'm also getting a furnace reset issue (which is why it wont start): Goodman furnace - blinks once then red light stays on.
Old 01-14-16, 09:04 PM
Received 379 Votes on 356 Posts
Can you post the model number for your new motor ?
I've got most of the wiring diagram or can get them quickly.
Old 01-15-16, 03:33 PM
Old 01-15-16, 04:08 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
230 volt gas furnaces are not very common. They are usually 120 volt. Post a picture of the furnace nomenclature (tag) so that we can verify that you have the correct voltage motor.
Old 01-15-16, 06:18 PM
I like the 120v---> 24v humidifier transformer cable tied and hanging there.
However.... I have to agree with Houston.... that is a 120v control board.
Old 01-17-16, 01:43 PM
Here is a pic of the old motor showing 115V.
http://i.imgur.com/aqHguYD.jpg
Looks like they gave me the wrong motor. I'll take it back tomorrow and swap it out.
Thanks for the help guys.
Old 01-19-16, 02:16 PM
Got the new motor; however, still can't get the furnace to start.
Seems to be stuck in lockout mode, I think. Is there a reset button somewhere? Turning off power, same think happens.
The red light blinks once and then is consistently on. Is that system lockout? Or "steady on" for replace control?
I took a video: https://vid.me/vfOM
Here are the codes: http://i.imgur.com/M9x5dJO.jpg
Also here is the old motor: http://i.imgur.com/950S3io.jpg
New motor they gave me (115v): http://i.imgur.com/0RfZAe7.jpg
Furnace model #XF900703A
Old 01-19-16, 06:56 PM
Grady's Avatar
To me, it's showing replace control. Maybe PJ or Houston will chime in with an opinion.
Old 01-19-16, 09:41 PM
Steady on is board failure.
Lockout is flash......flash......flash.......flash. A continuous single flash.
