Way to test whether pump or thermostat?
Old 01-18-16, 07:37 PM
A
WeatherMaker Infinity. In the past the condensation pump has failed twice and the thermostat once. I troubleshooted by just swapping out parts. Is there an easier way?
Don't have a problem now. Just trying to learn for future reference.
Old 01-18-16, 08:05 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
You can bypass a float switch in a condensate pump to see if it has locked out operation but I usually just clean the reservoir and blow out the drain line output.
If your Infinity furnace has an Infinity thermostat you can connect the connect the float switch to R and G and configure the thermostat to monitor these terminals as a float switch.
