Lennox furnace-code for open limit switch
Old 01-30-16, 04:50 PM
R
Hi, I have a lennox g40uh-36a-070-02 and have the code for open limit switch.
I have checked primary, secondary, roll outs, and pressure switches for continuity and all are good.
What can I be missing, or doing wrong?
Thanks
Old 01-30-16, 05:41 PM
C
The limits will reset when they cool down, but the furnace will be locked out for an hour. Are you checking the limits right after the furnace shuts down?
Old 01-30-16, 06:20 PM
Received 3,176 Likes on 2,852 Posts
If you are getting a code for an open limit than you missed one. Like Carbide said they will reset when they cool off. That means you need to check when it happens. I connect my meter to the control board and watch the limit from that location to see if one is actually opening.
Old 01-30-16, 08:00 PM
C
And make sure your filter is clean and dampers are all open.
Old 01-31-16, 08:18 AM
R
I found a loose wire at 12 pin! Looks like I got it licked!
Thanks guys
Old 01-31-16, 10:06 AM
That is a very common problem. Glad you got it fixed.
