ecobee 3 wiring help
Old 03-05-16, 11:47 AM
N
I bought an ecobee 3 and am attempting to hook it up, but am a little confused about the wiring to my furnace. a little help would be appreciated. Here is a diagram of what I have no to my existing thermostat: first side is thermostat, second side is furnace.
Rc - orange wire - R
Y - black wire - Y
G - green wire - G
R - red wire - Th
W - white wire - Th
the two Th connections are separate and go to the transformer? not sure exactly what to do here or if I need the adapter for the common wire. Thanks in advance for any help.
Old 03-05-16, 03:40 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
Do you have an extra wire to connect from the cooling transformer C to the new thermostat C?
The old R is now RH.
Old 03-05-16, 03:45 PM
A
Received 31 Votes on 27 Posts
More likely to be an old gas valve with those labels. Could one of the Th connections really be a TH/TR ?
Best bet would be that the R on the thermostat side can go to the Rh on the ecobee. And W would be W1
Old 03-05-16, 05:53 PM
Received 835 Votes on 782 Posts
Rc - orange wire - Rc
Y - black wire - Y1
G - green wire - G
R - red wire - Th (Rh)
W - white wire - Th (W1)
You need a 6th wire between the stat and your system for C.
N
I read through the wiring manual again and it looks like all i need are the first 3 wires on the diagram
rc (rh on ecobee) - r
y - y
g - g
My question now is what to do with the last 2 wires? Astuff has it right, it's an old gas valve and its th th/tr, but where do i connect those to the ecobee?
Old 03-05-16, 05:56 PM
N
I need to run a 6th wire? or can I use the adapter that comes with the ecobee for c wire?
