My A/C is not blowing cold air
Old 04-14-01, 02:43 PM
Guest
Arrow
I have an electric A/C unit that recently hasn't been blowing cold air. I have replaced the filters and cleaned the air ducts but nothing was working. Today I saw that my pipes were frozen where the air blows on the outside where the fan is. Is there any way that I can fix that or will the unit need to be replaced??
Old 04-14-01, 05:32 PM
PDF
Turn cooling off
and place fan switch to on.Tomorrow set cooling to on and check for cold air.If air flow feels weak your cooling coil may need a cleaning.If problem reoccurs system may be low on freon.Make sure you are not setting tstat to low.PDF
[Edited by PDF on 04-14-01 at 07:37]
