How to wire circuit board for furnace?
Old 05-07-16, 07:00 PM
O
Hi,
I've replaced the circuit board to my furnace but I don't know where to attach the power wires--one black and one white--to the circuit board.
Any ideas?
Below are several links to the circuit board. I'm pretty ignorant when it comes to this stuff, fyi.
http://cdn2.bigcommerce.com/server53...0.1280.jpg?c=2
http://imagizer.imageshack.us/a/img922/5928/YJFFZF.jpg
http://imageshack.com/a/img924/9066/G60RiC.jpg
Furnace Model #: AMS80703ANA
Circuit Board: PCBBF118S Goodman/Amana Gas Furnace HSI Ignition Control Board
T h a n k s !
Old 05-07-16, 07:27 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
In the picture below.... the black circle is LINE H or hot and the white circle is LINE N or neutral.
Old 05-08-16, 06:11 AM
O
Thanks Pete. I'll give it a go and let you know how it goes. : )
Old 05-08-16, 11:43 AM
O
Hey Pete,
So I connected the white wire to your suggested terminal; however, I also noticed that I already have a black wire connected to the "LINE-H" terminal. . .but I still have one black wire that is not connected to anything. From the looks of it, the unconnected black wire runs towards what I believe to be the blower motor.
Any idea what terminal this last black wire might connect to?
Here's a picture with white arrows pointing towards the black wire in question.
http://imageshack.com/a/img923/3857/xwAGmu.jpg
Old 05-08-16, 02:28 PM
Follow that unconnected black wire. Can't guess where it goes to.
It may go to the blower door safety switch.
Why do I see a capacitor with no wires on it ?
Is there a replacement cap somewhere for it ?
Old 05-08-16, 04:56 PM
O
Hey Pete.
So I know the unconnected black wire doesn't go the safety switch b/c there's already another black wire connected to the safety switch:
http://imageshack.com/a/img924/9819/2Lj2Ur.jpg
There's another black wire (and white wire) that connects to this part of the furnace:
http://imageshack.com/a/img921/1671/ksLpfs.jpg
And then the unconnected wire goes w/ a bunch of other wires to what I believe is the blower (but I can't trace it beyond this image here):
http://imageshack.com/a/img921/3383/MpjANe.jpg
Lastly, there is one orange wire--have no clue where its terminal is--but it goes to the same destination that the unconnected black wire does (to the blower I think). Here's an image:
http://imageshack.com/a/img923/1138/BiANM9.jpg
Maybe this orange wire is related to the capacitor?
Old 05-08-16, 07:35 PM
Check and make sure the blower works with the A/C and heat modes. It looks like you have a wire on COOL H and HEAT H. That would mean the black and orange wires get placed on the PARK terminals which is just a place to put un-needed fan speed wires.
Old 05-09-16, 04:10 PM
O
Pete. . .thanks immensely for your help. Furnace seems to be working. I couldn't have done it without you--this means a lot! Thanks! !
Update: So now I can get the furnace to turn on (which is pretty exciting), thermostat is set to 76* degrees and current temperature is 72*. . .but now the furnace turns off after about 10-20 seconds of running.
The first time I had it on it ran for about 1 minute, although I didn't notice air coming from the vents (vents are open, pipes leading from furnace to vents are warm/hot). But the furnace seems to be mimicking the same symptoms it was before the circuit board went out. = /
Any ideas Pete?
Old 05-09-16, 04:35 PM
O
And just FYI, I cleaned the flame sensor a while ago when the furnace was exhibiting similar symptoms and that did not help. The only way I can get the furnace to turn back on is by turning of the safety switch and then pressing it again--and then the furnace will turn on for 10 secs or so, and then turn back off.
Old 05-09-16, 04:55 PM
What is the red diagnostic LED doing ?
Old 05-13-16, 04:43 PM
Received 3 Upvotes on 3 Posts
Did you wire the capacitor
Old 05-13-16, 05:15 PM
No.... I mentioned it before and you got me thinking about it. In the following picture is your blower capacitor. It is unconnected. When I look thru your pictures I see a brown wire hanging and not connected. That should go to one of the cap terminals. Look for a brown wire with a white stripe... that should go to the other terminal. There is no polarity on the cap.
