Single Wall Duct Clearance
Old 05-29-16, 09:18 PM
P
I'm building a wall in my basement that I think won't quite meet code for clearance between a single wall gas exhaust and combustible. At the closest, the pipe is 4.5" from the wall. Picture shown below!
I think I can get this to meet code, by installing a "Heat Shield".
Forum Post
Video
Two Questions... (Edit Three)
Can anyone provide me a link to appropriate code for this process?
Are the heat shields made by bending a piece of sheet metal? I can't seem to find one at my local building supply.
The ol' man is trying to tell me I can put fiberglass insulation around the pipe to keep the heat in. Thoughts?
Pictures of pipes
Size:  32.8 KBName:  IMG_5953.jpg
Size:  33.8 KBName:  IMG_5954.jpg
Tags: Vent Clearance Furnace hot water heater single wall pipe 6" inches 1"
Old 06-11-16, 10:51 PM
Houston204's Avatar
Received 17 Votes on 14 Posts
I would refer to the furnace manual for the correct venting requirements.
I would be surprised if single wall vent pipe is spec'd.
Old 06-12-16, 01:06 PM
SeattlePioneer's Avatar
If the furnace has an inducer motor, it's an 80% efficient furnace and should have double wall vent pipe to prevent combustion gases from condensing in the vent pipe.
If it's an older furnace that has a draft diverter, single wall vent pipe is OK.
Clearance to combustibles with single wall pipe is 6".
I don't know about how a heat shield affects that. You'd have to do more research than I can provide.
