Reset?
Reset button? For what exactly? If the heat isn't operating have you reviewed the diagnostic codes on the control board?
There isn't one.
If you turn the power to the furnace off, then on, the furnace resets.
If you are having trouble, take the cover off the burner compartment of the furnace.
Observe the sequence of events which occurs when you turn up the thermostat, and report that sequence here, in order and in detail.
