Rheem 90 Plus - won't ignite
Old 11-03-16, 01:16 AM
N
Blower starts
Ignition thing glows
No gas ignition
Main fan/blower begins as if nothing is wrong
Fan stays on for a minute or two and shuts off
The furnace is the only gas appliance in the house so I can't really test elsewhere with regards to the gas supply. I tested the gas valve wires during this ignition cycle and couldn't get any VAC to register on the meter.
Serial number has the furnace as a 1995 product.
Old 11-03-16, 01:24 AM
N
Also, there are two green lights in the lower compartment that stay that way throughout.
Old 11-03-16, 07:21 AM
R
Is the board outputting voltage to the gas valve during trial? What code is the furnace shutting down on? Is gas on?
Old 11-03-16, 12:31 PM
SeattlePioneer's Avatar
You need to be able to verify that you have good gas pressure to the electric gas valve. On way to do that is to shut off the manual gas valve at the furnace, open the union or flex connector, and briefly turn the gas back on for a second or so.
If that is OK, you need to check to see if you have 24 VAC to the electric gas valve being switched on after the HSI heats up. If you do, you may have a burned out gas valve. If you don't, a failed circuit board.
