Payne vs Goodman furnaces
Old 11-22-16, 08:10 PM
L
Do those in the HVAC trade have an opinion on Goodman vs Payne brands for natural gas furnace and AC? It looks like I can get 2 stage heating and ECM blower on the Goodman for the same price as a single stage for the Payne. I'm removing a Conquest 90 that has done well for 20 years.
Old 11-26-16, 05:47 PM
Grady's Avatar
Received 35 Votes on 33 Posts
In general there is not a lot of difference from brand to brand. As I have said on this forum more times than I care to count, the "best" system is whatever brand the best installer is using at the time. It's 95% installation & 5% equipment.
Old 11-26-16, 10:19 PM
user 10's Avatar
Received 45 Votes on 39 Posts
If you care about american jobs, buy the goodman, payne is made in mexico or will be in under a year.
the goodman gmvc96 should be a good product internally, but the cabinet may be a little thin.
goodman parts will be cheaper than payne which is just low end carrier.
to fully benefit from 2-stage/variable speed you must get it sized right and it has to be controlled by a 2-stage thermostat. otherwise, you won't get long cycles on low, just constant low for 12 minutes or less, high for a short time, then off. The 2-stage stat only brings on high fire when absolutely necessary and can down-stage to low. without it, the furnace just times out, runs full blast for the rest of the cycle.
Old 11-26-16, 10:34 PM
R
Received 123 Votes on 117 Posts
The quality of the installation matters a lot more then the name on the box.
Proper load calculations, equipment selection and installation quality are what your looking for here.
Old 11-26-16, 10:37 PM
R
Old 11-27-16, 02:17 PM
SeattlePioneer's Avatar
The one big advantage of Payne and the other Carrier brands is that Carrier makes by far the largest number of furnaces.
That means that if a repairman can fix ANYTHING, he is probably going to be able to fix a Payne, since he sees those so often.
Also, for the same reason, he's much more likely to carry parts to repair a Payne furnace than that of other manufacturers.
That might mean that when you need a part on a Friday afternoon on a payne furnace, you get it fixed then and there, rather than waiting until Monday when parts can be purchased for another furnace.
Old 11-27-16, 02:23 PM
user 10's Avatar
parts availability will vary by area. Goodman is also common so parts shouldn't be an issue.
carrier parts are extremely expensive. a ventor motor for a 2-stage carrier online is $400 at cost, if the dealer fixes it count on paying 600 to 800 for that.
Old 12-08-16, 02:13 PM
L
Thanks for your input, pros.
