York gas furnace
Old 12-07-16, 07:06 PM
York gas furnace
Hi I have a York gas furnace model number TG9S080C16MP11A
Over the last couple of weeks my furnace won't light and blow warm air, I am now getting 7 flash code ignition lock out due to retries I have cleaned the flame sensor and shut power off to unit for 10 min, when I turned unit back on it does the same thing motor kicks on ignitor gets red flame turns on for 2 seconds and then kicks off it cycles like this 3 times before the blower fan kicks on and blows cold air. Any ideas would help thank you
Old 12-07-16, 07:12 PM
Received 30 Votes on 28 Posts
Do you have a meter capable of reading milliamps to test the flame sensor?
Old 12-07-16, 07:17 PM
Received 1 Vote on 1 Post
Welcome to the forums. The next time you start the furnace, if the burners actually light for a few seconds and then go out, look at the flashing code and see what it is saying after the first start up.
Your problem sounds like a flame sensor but those usually don't go bad. Check for a loose wire from the sensor to the control board. Also be sure that all of the burners are lit - not just the first one or two.
Old 12-07-16, 07:38 PM
I just started it up and it lights for a couple seconds and goes out all 4 burners are lighting up, all the wires look good, it still gives me 7 red flashes
Old 12-07-16, 07:42 PM
Yes I have a Klein CL1000 meter I'm pretty sure it does milliamps
Old 12-07-16, 09:05 PM
Received 265 Votes on 248 Posts
You need to measure ua ..... microamps..... and that meter will.
You disconnect the single wire to the flame sensor rod. Connect either probe to the rod and the other probe to the wire that was on the probe.
You will only read current when a flame is established so keep your eye on the meter. Let us know what you get. It should be around 4-6 ua.
Old 12-08-16, 04:38 PM
Thank you I just did this test and I had 5 on my meter
