York Diamond 80, with stat off, the fan started itself and never stopped
Old 12-15-16, 09:36 AM
I have York Diamond 80 furnace. Some day, when the stat was in off status, the fan started itself and kept running for ever. I disconnected the power supply and reconnected it, the furnace was quiet for about 1 hour, then the fan started itself again and couldn't be turned off. I replaced the filter but the problem is still there. Any idea?
Old 12-15-16, 09:40 AM
Received 327 Votes on 306 Posts
Welcome to the forums.
Does the furnace make heat ?
Old 12-15-16, 09:46 AM
yes, when I reconnected the power supply, it worked normal. The furnace was ignited when I set the temp higher than the room temp and the fan also started. And I was able to turn it off including fan by operate in stat. But about one hour later, the fan started itself and couldn't be turned off anymore.
Old 12-15-16, 09:55 AM
York Diamond 80 is just a trade name.
The full model number is needed for your furnace.
It will be on an ID tag on the inside wall near the burner.
Old 12-15-16, 10:11 AM
Will check in the evening. Thanks.
