Holes/gaps in my ducts
Old 12-20-16, 10:43 AM
T
Where round ducts come out of rectangular ducts, there are a lot of holes like in the photo.
It is pretty small, but there are many of them. Should I cover them all with duct tape or are they supposed to be there?
Thanks
Old 12-20-16, 03:32 PM
Tolyn Ironhand's Avatar
Received 370 Votes on 320 Posts
Sealing up duct work is a good idea. Do not use Duct tape, that is old technology. Instead use mastic: Water Based Mastic Half Gallon Tub-WBA50 - The Home Depot or metal foil tape: Nashua Tape 1.89 in. x 50 yd. 322 Multi-Purpose HVAC Foil Tape-1207792 - The Home Depot
Old 12-20-16, 06:29 PM
T
Thinking about it some more; all the leaks are into the basement, and the basement is heated.
Do the leaks really matter?
There are 4 heat ducts in the basement. I have dampers closed on all 4, and one is capped. Temperature is about right, now. If I closed up all the leaks, i might must have to open a damper to compensate.
Any good reason to just not leave well enough alone?
Serious question... I really don't know.
Old 12-21-16, 05:45 AM
B
Received 113 Votes on 99 Posts
If the remainder of the living space is being adequately heated, the leaky ducts in the basement is of little consequence. The purpose of the ducts is to provide a conduit for air to be transported from a source to a destination with minimal change. Cool air at minimum flow is of little value at heating a volume. Therefore, leaks in ducts should be fixed. My guess is the ducts you cant see are also leaky
and increasing your heating expense.
