York furnace not working
Old 01-02-17, 02:18 PM
Hello all. I'm brandy new here and have a problem I hope I can get some advise on. I have a York furnace thats not working. It's a "York 90" and is our main zone and it's installed in the basement. It's the original equipment installed when we built our home January of 2003. The draft inducer kicks on but the blower for the heat does not. I messed with the hose from the pressure switch and got it to work. I set the thermostat for 68, it was 58 in the house this morning, and it heated up as normal until it hit 66 and then it stopped working. The draft inducer stayed on though. I turned off the emergency switch next to the furnace for a few minutes, made sure the hose on the pressure sensor was secure and it fired up again, only to shut itself down at 66 degrees again. Any ideas?
On a side note I can turn the fan on and off for the furnace via the thermostat in the dining room.
Sorry for the book, just wanted to describe exactly what's happening.
Thanks
Bob
Old 01-02-17, 02:38 PM
I should add the red light inside of the cover flashed 3 times, indicating an open pressure switch.
Old 01-02-17, 03:22 PM
Received 33 Votes on 30 Posts
Check venting for obstructions. If clear check draft on inducer with a manometer.
Old 01-02-17, 04:03 PM
Received 343 Votes on 321 Posts
Welcome to the forums.
Also pull the hose off the inducer blower and make sure the little tiny orifice is clean.
Name:  DI nipple.jpg
Old 01-03-17, 12:52 PM
Thanks for all of the suggestions. I appreciate it. It turned out to be the pressure switch.
