Old oil furnace snapped fan belt
Old 01-29-17, 08:26 PM
T
Howdy,
My furnace died today. I noticed on my thermostat it was making a heat call, and no air was being moved. I went and inspected and found that the belt snapped, so the motor was just turning away.
Replacing the belt seems simple enough. I'm just curious if anyone recommends any additional work I should perform while in there? I"m not sure if the bearings can be lubed in the motor/fan, or what to use if they can be.
Thx!
Old 01-29-17, 08:30 PM
Received 3,424 Upvotes on 3,070 Posts
On most of those old belt driven blowers there were oiling points.
That motor probably has oil ports too.
Old 01-29-17, 08:42 PM
T
Any recommendation on what to use for oil? I bet she's a bit dry. How freely should the squirrel cage fan spin?
Old 01-29-17, 10:07 PM
Light motor oil. 3 in 1 oil is good.
The squirrel cage wheel should spin pretty freely.
Old 01-29-17, 10:15 PM
T
This one spins, but it feels kinda "heavy" on the bearing. How heavy is the wheel?
Old 01-29-17, 10:17 PM
You should be able to give it a spin and it should keep going by itself.
Old 01-29-17, 10:36 PM
T
hmm she's pretty stiff
https://youtu.be/Ek2KGaAkGjo
Old 01-30-17, 11:31 AM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
It does look pretty tight. Unfortunately, those bearings do not appear to have any lube points. If they are sleeve bearings, you may be able to force some oil in there around the shaft, but I would plan on replacing them.
Old 01-30-17, 11:42 AM
T
Thanks, that is sort of what I figured.
I got the new belt on and it's running much quieter now, and seems to be moving air a bit better. It got down to about 50 in the house last night, so it was a bit chilly. The furnace is running A LOT now trying to get things back up in temp. Definitely way more quiet though.
