When the furnace is on it smells like something is burning and gets hot
I changed the filters. The code flashed four times I turned the power off and found a switch that has an on and off on it and turned it off then back on. I then turned the power back on it then flashed five times, valve energized with no call for heat, it's still cold in here.
It is a Coleman furnace. While you wait on our guys to wake up, take a look at the troubleshooting guide for the Coleman. It may or may not help answer questions. https://www.repairclinic.com/RepairH...roubleshooting
That happened to me a couple years ago. I wish I had a picture of the high-limit switch that stuck and allowed the furnace to overheat. The switch melted and the plastic formed a long drip shape. It was conical...and comical.
This model is one of the ones involved in the Coleman recall for defective/cracked heat exchangers. If it hasn't been checked recently..... it should be. It sounds like it may be damaged.
This shows what happens to the old heat exchanger.
dgatprogram.com/doc/035-20530-001-b-0804.pdf
Post #8 identified a cause for concern for your furnace. Has this been checked and verified as ok? Carbon monoxide is deadly.
