Rheem furnace thermostat upgrade
Old 03-08-17, 09:56 AM
I have a Rheem classic 90 plus multi stage natural gas furnace/ac/humidifier unit that was new in 2000. I would like to upgrade to one of the newer thermostats, something I can see in the dark and make changes in the settings from my phone. When I reached out to Rheem they would not tell me which thermostats will work correctly with what I have (even though they sell a few like this) , they recommended that I contact my local repair center. How hard can it be to to connect 9 wires to a Tstat especially when my background is electronics?
Any help is appreciated.
Old 03-08-17, 10:52 AM
Post the model number of the furnace and we can help you. 9 wires??
Old 03-08-17, 10:58 AM
Received 331 Votes on 309 Posts
Yeah... 9 wires is a little scary.
Old 03-08-17, 11:12 AM
Rheem Classic 90 Plus furnace
Old 03-08-17, 11:14 AM
That's the series name. You can find the model number in the burner section of the furnace.
That's a trade name. The model number is behind the burner access door.
It's on an ID plate on the side wall near the burner.
Old 03-08-17, 11:19 AM
Will this help? This is the wiring in the current Contour Comfort control stat.
Old 03-08-17, 12:08 PM
The only terminal I don't recognize is V. I think the Honeywell RTH 6580 WF would work for you.
Old 03-08-17, 03:00 PM
The model number is RGFD-07EMCKS
Old 03-08-17, 04:01 PM
Correction the black wire is connected to SO not V. I think Pj could find more info on this model than I can. He should be along later this evening.
Old 03-08-17, 04:14 PM
With the WiFi stat you'll get wifi control but you will lose the variable heating rate. The V terminal stands for variable furnace modulation controlled by a modulating thermostat.
This would be the 6580 wiring......
Red = R/Rc (leave jumper in place)
Tan = C
Green = G
Yellow = Y
White = W
Brown/Black = may possibly go to W2 but if it does..... dip switches at the furnace will need to be changed for two stage heating.
Furnace manual........
/Installation_instruction_Rheem_RGFD_en.pdf
Old 03-09-17, 03:59 AM
Ouch, not sure I want to drop the modulating feature, that changes everything.
Thanks for the PDF, I have a car copy but its rough.
Old 03-11-17, 06:13 AM
I had sent a message to Honeywell regarding this and after reviewing the pdf you sent they thought these Honeywell thermostats should work correctly:
RTH6580WF
RTH9580WF
TH8321WF
They said
However the V terminal will go into W2 instead of V.
Old 03-11-17, 08:13 AM
Correct.... that's what I said. You lose the variable firing and it becomes two stage heating.
There are jumpers that will need to be changed.
The Honeywell stats don't offer variable operation.
Old 03-11-17, 10:36 AM
Bummer, I really want to keep it modulating.
Old 03-11-17, 12:14 PM
How about the Aprilaire 8920W, that looks like it will even make toast!
Old 11-07-17, 04:25 PM
It might do toast but according to the manufacturer it wonít operate the modulating furnace. Iím surprised that no one makes a thermostat for this.
Old 11-07-17, 05:17 PM
I’m surprised that no one makes a thermostat for this.
Not yet....... that I'm aware of.
