Propane wall heater won't adjust
Old 03-16-17, 04:48 PM
R
Just installed a dyna glow propane wall heater. Cannot adjust heat setting. Always on high setting even when the knob is on 1
Always runs on high reguargless of knob setting
Old 03-16-17, 05:00 PM
Received 1,509 Votes on 1,396 Posts
Welcome to the forums.
Is that one of the vent free type heaters ?
What is the model number ?
Old 03-16-17, 05:09 PM
R
Yes wall mount vent free
IR30DTDG-2
Old 03-16-17, 07:06 PM
Just a brief warning.... a vent free heater like this gives off CO and uses up available oxygen so it needs a source of fresh air and shouldn't be used in a bedroom or where people sleep.
That type of infra heater doesn't operate well on low.
That control is not a variable flame control.... it's a thermostat.
In case you didn't get the full manual for your heater....
GHPGR001/Install_Instruct/OM_IR30DTDG-1/2GHP.pdf
Old 03-16-17, 07:22 PM
Received 3 Votes on 3 Posts
They aren't legal here. Must be vented
Old 03-17-17, 01:18 PM
R
Ahhh
Thermostat thing makes since. Also thanks for link to the owners manual. Never used this forum before by will be back for sure!
Thanks for the help...
Also need to change my state it was pulling up as OK and not OH.
