Heat, A/C, and fan stopped working
The unit is a Rheem (heat pump, if that matters)
I tried jumping the R + G at the thermostat and it still doesn't turn on. Also checked the float switch at it appears dry as well. And obviously checked the breaker.
Then I got someone online to help me but then he got lost. He had me check the voltage on the following wires in the air handler. This was the result:
28vac between R and C
0vac between C and Y
Anyone got any ideas?
Thread moved to heat pump forum.
28vac between R and C means the transformer is good and the system has power. 0v between C and Y means the stat is not calling for cool.
Remove thermostat from the base. Should pull off.
Check from ............
R to Y
R to G
R to O
24vac on all three would indicate a defective thermostat.
R to Y
R to G
R to O
And if I get 0vac on Y and G (no O wire)?
Based on this, is there anyway for me to 'hotwire' this thing, as it's really hot. lol
edit: So I had another thermostat here. I hooked it up and it won't even power up (the original thermostat used batteries).
Sorry..... your Rheem uses a B terminal only for heat.
At the air handler..... try jumping R to Y and G.
If this works.... something is opening the R wire.
Double check the float is operating correctly.
Any chance you can explain that a little more in depth, as I really don't see those designations in the air handler. If it helps, this is what I'm working with
edit: Also, is the float open or closed by default? Can I just short those wires to test?
Sorry about my apprehensiveness. I'm now dealing with stuff that I don't fully understand and want to make sure that I don't screw something up. The R and C I tested were on the circuit board. There is a yellow and green wire in there, but I don't think those are the ones you're talking about..
This is the point where the air handler joins the thermostat and to the outside condensor.
We are interested in the thermostat cable. Carefully pull the splices out and apart to see them better. Don't take any connections apart until you can see where they go.
Remove the wire nut from the red wire connection and touch it to the green wire connection. That should start the blower. Connecting the red wire to the yellow will start the outside condensor running although it may take 5 minutes.
There is a.....
red wire for 24vac to the stat
blue wire for common C to the stat
green wire for blower control
orange wire for ??
white wire for electric reheat
brown wire for B - 24vac power to condensor for heating mode.
There is a.....
orange wire for ??
Ok..... since you have a meter.... check that red wire to either any metal chassis or to the C terminal inside that control box.
Ok... now you need to follow the heavy red wire towards the control box. You told us you had power from R to C which means that red wire should be powered. We need to find out what is in that red line that is stopping the 24vac. The float switch should be one item in that red line.
Okay, so the float switch runs 'through' a yellow wire. One side connects to the thermostat pairs, the other side connects to the wire that goes to the condenser.
The red wire terminates on the PCB in a different place than I checked originally. Hopefully this pic makes sense:
