Carrier Ultra Hi-Efficient 2-Stage 58MVP60
Hi and good to be here...I was lucky enough to get an inducer assem. from a junker/scrapper fellow ($3). It appears that RT1 is fried on the circuit board. Does anyone know the value or part so I can order one.
I've heard this mentioned on other threads and where they got them...but no specifics?
Thanks!
Ben
Thanks!
Ben
Welcome to the forums.
An inducer assembly is a motor with a blower.
I service furnaces but I have no idea what you are looking for. If it's a part built into the motor.... it's not considered a replaceable part but it should have a value on it.
It's on the motor circuit board...here is an old thread reference to it...markcutter refers to a "blower assembly" but the number is the inducer.
https://www.doityourself.com/forum/g...tor-noise.html
I believe the part you need is an SG348. I call it a varistor.... but it's also called a thermistor. Just search using the part number and vendors should come up.
