goodman the dependable ninety two
Old 12-03-17, 06:48 PM
blower comes on, cycles three times and does not ignite....
error code then comes on red light every 4 seconds
Old 12-03-17, 07:12 PM
Tolyn Ironhand's Avatar
Received 67 Votes on 59 Posts
1 flash means the furnace failed to light after 3 tries and is locked out. You must turn off power to furnace and then turn back on to reset. Furnace will try to light again. Watch while it tries to startup. You should see/hear:
1)Draft inducer start up.
2) Click and hot surface igniter should glow.
3) Main burner should start
4) igniter will turn off and after a while main blower fan should start.
Watch closely for what it does or what it does not do and report back.
