Locating flame sensor in furnace?
Old 12-10-17, 11:42 AM
H
I have to clean my flame sensor but I cannot locate it. My heater blows cold air and hot air sometimes.
Old 12-10-17, 11:57 AM
Received 1,523 Votes on 1,406 Posts
Welcome to the forums.
I operated on your picture.
You don't have a flame sensor rod to clean. You have an intermittent spark lit pilot light. That is an assembly connected with that orange high voltage spark wire and that silver pilot gas tube. That assembly gets taken out and cleaned. More than likely you have dirty pilot light or pilot light orifice. The pilot has to be lit and be a full size flame before the main burner can light and stay lit reliably.
Not really an easy DIY job. You may want want to call your gas provider and see if they offer service. I've found the gas providers usually have excellent service and they're not trying to sell you a new furnace to replace that older one you have.
Additionally..... if your burner stays lit for several minutes before shutting off then you don't have a flame sense problem. More like an over heating problem. Check for a clean filter as well as open registers and returns that aren't blocked.
Old 12-10-17, 02:50 PM
H
Thank you so much Pete! I'll get it checked out
