Fan won't work on Auto
Old 12-23-17, 10:32 AM
K
Recently the fan on my whisperheat by lennox stopped working. I've been trouble shooting and no remedies have worked. I started by replacing the blower motor itself as well as the capacitor. Upon further inspection the circuit board was visibly fried so I replaced that as well. After those replacements the fan will come on but only if switched to, "on," manually. I changed the high limit switch and tstat today. Nothing has worked to get my fan to come on in the auto position. Any thoughts??
Old 12-23-17, 10:40 AM
Received 4,139 Upvotes on 3,717 Posts
Welcome to the forums.
Any thoughts??
Yes.... we need the model number off the ID tag inside near the burner.
Old 12-23-17, 10:42 AM
K
M/n: G20q3e-75-6
s/n: 5897g 09112
Old 12-23-17, 11:27 AM
Your blower is controlled directly from the control board. After a demand for heat..... the blower is preset to come on in 45 seconds. The shut-off time is user settable. If the blower doesn't come on in the heat mode.... there is an issue with the control board.
Another possibility is wiring error. The board supplies two blower outputs......
1) cooling and FAN ON speed.
2) heating fan speed.
You should see heat and cool blower connections. You can swap them to see if the heat works then. If you aren't sure..... post a picture here of your wiring and the board. How-to-insert-pictures
This should be the manual for you furnace and the blower info is on page 20.
Furnaces/Lennox_G20_IOM.pdf
