Furnace cycling ON & OFF
Old 12-29-17, 09:26 AM
H
My furnace is cycling ON for approx 1 min 15 sec then off for 58 seconds then back back for 1 min 15 sec.
Heil unit 30 yrs old
Cleaned secondary heat ex-changer & blower, made sure all vents where open and returns were free from anything obstruction airflow yesterday and it is stll cycling OFF-ON
Any ideas? The unit is still heating the house fine.
I know it an old unit, just want to see if it can be fixed wo large expense before i have to purchase a new unit/
any help would be greatly appreicated
Old 12-29-17, 09:49 AM
Does the fan keep running or every thing shut down ?
Old 12-29-17, 12:53 PM
H
yes. blower keeps running....flame goes out then reignites.
Old 12-29-17, 02:25 PM
Sounds like the Hi-Limit is tripping. Check the supply temp and let us know.
Old 12-29-17, 07:53 PM
Received 3,416 Upvotes on 3,063 Posts
It does sound like it's tripping on high heat but that rate is pretty fast. Usually the time periods are slightly longer.
Do you know what controls the blower in your furnace ?
A fan/limit control, directly from the board or..... ?
You could try posting the model number which is on an ID tag inside near the burner.
Old 12-30-17, 04:50 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi,I would assume you changed the air filter.
Geo
