Can you review my connection pics for Honeywell wifi thermostat?
I have my Honeywell WiFi thermostat installed but it keeps rebooting while the heat cycle is on. I saw a thread where this was happening to someone else and removing the filter helped them, but that didn't work in my case. Can someone check my wiring pics? This is a Carrier 58GFA High-Efficiency Induced-Combustion Upflow Furnace (gas). Thanks in advance for any help and have a happy and safe new year.
The thermostat is rebooting. When the heat comes on, I watch the stat, it's fine for a few minutes and then the stat reboots and the heat stops until the stat is finished rebooting and then the heat comes on again. It takes a long time to get the house heated up when it's running in fits and starts like that. It's consistent.
Your wiring is fine. Your furnace is cycling on high heat. When an overheat is detected the safety switch opens the power to the R terminal.
You need to determine why the furnace is overheating.
