Rheem Classic 90 Furnace - blower shut down
I have a Rheem Classic 90 furnace, it is about 15 years old.
The unit will heat the house very well. Sometimes while the furnace is on and heating, the blower stops for about 15 seconds while the burners continue to burn. After 15 seconds, the blower starts up again and works fine.
This doesn't happen all the time. I have noticed it before when the filter needed replacement. After replacing the filter the unit seemed to work fine. I just replaced the filter but the blower will stop every so often.
Fan limit switch????
Which blower are you referring to...... the draft inducer blower or the main air blower ?
manual/1258631/Rheem-Rgrj-Series.html
