Beckett AFG with Honeywell R7284 - Valve on delay
Old 01-03-18, 06:37 PM
T
Hi,
Thanks in advance for any and all advice.
The Burner and control are on a Weil Mclain Gold oil furnace.
all are about 5 years old.
The burner will not ignite. The Honeywell control displays "VALVE ON DELAY"
This happened once last week, I reset it, and has been ok until today. Not sure if the Suntec solenoid is bad, or even how to test it.
Edit to add; I am in New York and its 16 degrees outside. thank goodness for the wood stove.
Thanks again,
Tom G
Old 01-04-18, 04:26 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Tom,
When the control is showing "valve on delay" it should be counting down, second by second. At the end of "valve on delay" there should be a click & the solenoid opening. Then, you go into "trial for ignition". If no flame is sensed during that time, the control will lock out.
