Age of Luxaire Acclimate 9C Series ??
Old 01-05-18, 04:24 PM
T
I have a Luxaire Acclimate 9C series furnace. How would I identify the age
of this unit?
Model # LP9C080B 12MP 12CA
Ser # WON9443839
Thanks!
Old 01-05-18, 04:38 PM
Received 4,139 Upvotes on 3,717 Posts
W0N9443839
2nd and 4th digit = year = 09 = 2009
Are you sure the third letter is an N ?
3rd digit is the month. N is not listed as a month.
Old 01-05-18, 04:40 PM
T
The third letter is definitely is an ďNĒ yes
Old 01-05-18, 05:08 PM
T
Thank you pjmax! I now know how old this unit is!
I had an idea it may be around 10 yrs. Iíve put a new inducer fan on last year and just replaced the drain tank. I was getting water in the pressure switch lines from a bad gasket seal on the inducer fan / drain tank seal. Iím thinking the water didnít do the pressure switches any good, it now seems lazy to fire all 4 tubes. It was firing fine before I changed the tank today 🤔
Old 01-05-18, 05:59 PM
I tried checking further. In that series of serial numbers it doesn't list an N.
The year part is accurate.
Old 01-05-18, 08:58 PM
T
Thank you!👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍
